How to adjust f-18 shocks - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 4 (permalink) Old 03-04-2009, 06:54 PM Thread Starter
just as it says i need help adjusting my shocks, i bottom out pretty hard on dune transitions and bucks heavy in the whoops. which clickers do what and i know it has been talked about allot but i am not a shock guru. i need basic instructions. on what does what,
jlineracing20 is offline
post #2 of 4 (permalink) Old 03-04-2009, 07:04 PM
whats your pre-load ride height set at bottom of skid plate front and rear, i set mine at 10.5"rear and 11.5" front, then 0 out the other adjustments and play with them by feel, but you need pre-load right to start.
post #3 of 4 (permalink) Old 03-04-2009, 07:07 PM Thread Starter
i set the springs to full way out then tightend them about 3/4 of and inch. i will try to zero out the adjustments. is that right in the middle? or all the way turned in or out?
post #4 of 4 (permalink) Old 03-05-2009, 05:18 AM
underdog's Avatar
If you call up I-Shock they have/had great support.
I called them after i bought mine.
Here are my notes.
HydroDynamics USA, Inc.
West Coast Regional Office
9303 Bond Ave. Suite C
El Cajon, CA 92021
HydroDynamics USA, Inc. : Home of the iShock™
Model: F-18
Technical support: 619-390-2430
One week turn around for shocks sent in.
Shock controls all adjusters
 Turning clockwise: stiffens / slows
 Turning counter clockwise : softens/ speeds
Top of shock:
 Brass screw = Low speed damper (controls shaft velocity) Slow rolling terrain.
 Blue Nut = High speed damper (controls shaft velocity) Big whoops and air.
Bottom of shock:
 Brass screw = rebound control
(how quick shock recovers from compression)
Spring Lengths and rates:
Rear springs: The rear shocks come stock with: 375 rating.
Spring rates available for the rears are: 400 and 425.
9.25 inches = Resting length of rear springs
8.50 inches = Max preload length of spring
Front springs: 220 spring rating - no optional front spring rates available at this time
11.40 inches = Resting length of springs
10.25 inches = Max preload length of spring
Nobody is perfect, I am a perfect example
06 Rhino 660
underdog is offline
Fabtech shocks ? laveydude Yamaha Rhino Suspension Discussions 5 03-16-2009 07:35 AM
fox shocks thrillerrob Yamaha Rhino Suspension Discussions 14 02-24-2009 11:08 AM
Blackline 72 inch plow, Hydraulic angle adjust ebri Yamaha Rhino's & Rhino Parts For Sale 1 01-07-2009 08:56 PM
08 SE ressi shocks ljb Yamaha Rhino's & Rhino Parts For Sale 4 12-15-2008 08:22 AM
what shocks to run???? sandjunky Yamaha Rhino Suspension Discussions 0 11-22-2008 10:15 AM
