Walker Evans shocks - Yamaha Rhino Forums - Yamaha UTV Forum
post #1 of 36 (permalink) Old 07-14-2008, 07:47 PM Thread Starter
DuneRocket's Avatar
Walker Evans shocks
Is anyone running the heavier spring rates 475,275lbs on their 2 seater? If so how does it ride?
DuneRocket is offline
post #2 of 36 (permalink) Old 07-14-2008, 09:44 PM
That seems similar to some i-shock setups. Is this on stock suspension??
post #3 of 36 (permalink) Old 07-14-2008, 09:46 PM
eating popcorn,, I have these shocks so i figured i would tune in and learn something.
post #4 of 36 (permalink) Old 07-14-2008, 10:13 PM Thread Starter
DuneRocket's Avatar
Yes it is a stock. What im getting at is eversince I put these on it lowered the car about 3" I hit everything on the bottom now. I have turned the preload up but, acts kind of wierd. I am adding a winch,spare tire and a few other things I didnt know if that would be enough to justify the heavier springs.
I am also thinking with the heavier springs it would help with the ride height.
Is my thinking way off?
post #5 of 36 (permalink) Old 07-14-2008, 10:53 PM
Makin' Trax's Avatar
Your not thinking way off at all. The problem is what rate? Right? Here is a way to figure out what you need. Regardless of what spring rate you now have, but you need to know what the spring rate and the free length is, jack up the car, reduce all the preload to "0" preload on both shocks. Let it down, move it forward and back some to let it settle. Make sure to add driver, passengers, cargo, etc. Now measure the length of the spring under load. Multiply the distance compressed by the spring rate and that will give you the static load per shock at ride height. Lets say it compressed 3" and you have 400lb. springs. Then there is 1200lbs. static load. Ideally you want about 1/2" to 1" of preload and the car to sit at approx. 25% with the short 5" shocks. That would be an additional 1.25". So 1200lbs. divided by 2.25 = 533.33 springs. Now the car will sit at the desired ride height with the normal load and the proper preload. This is only an example to show you how to determine what you need. FYI, with the AFCO's 2 seat rear springs are 300# to 325#, 4 seat/utility 350# usually to 400# for a guy that runs hard with 2 adults in the rear.
Makin' Trax is offline
post #6 of 36 (permalink) Old 07-15-2008, 03:12 PM Thread Starter
DuneRocket's Avatar
I will do all that a see where I am.
Thanks for the help.
post #7 of 36 (permalink) Old 07-15-2008, 03:39 PM
Is that rhino that heavy? I will check this method with mine also, the rears are only 200 and fronts are at 175. and it does not get very low at all.
post #8 of 36 (permalink) Old 07-15-2008, 03:45 PM
RoamRocker's Avatar
those seem really soft to me Rog.... i guess it all depends on your setup. Im running 225 up front and 325 on the rears... thats for my 2 seater..
RoamRocker is offline
post #9 of 36 (permalink) Old 07-15-2008, 04:08 PM
Alot depends on the shock angles and ratios. So there should not be a blanket statement like that IMO, but I will check this method for sure.
Actually I had 250's on the rear it was kicking my ass.
post #10 of 36 (permalink) Old 07-15-2008, 04:09 PM
RoamRocker's Avatar
yup... your running the LSR kit?
Long travel w.e.r shocks [email protected] Yamaha Rhino's & Rhino Parts For Sale 24 08-04-2008 09:45 PM
Bilstein shocks question BML Yamaha Rhino Suspension Discussions 5 07-14-2008 02:59 PM
Elka Shocks! jimmmyzz Yamaha Rhino's & Rhino Parts For Sale 1 07-07-2008 08:37 PM
SkyJacker Shocks Bryan M Trucks, Trailers, Towing, and Hauling Discussions 4 06-28-2008 06:32 PM
elka shocks $1000 bordhead Yamaha Rhino's & Rhino Parts For Sale 11 06-25-2008 07:26 AM
