Wasn't running when I bought it. Lots wrong in the engine that I've worked on, but here's the short story. Rebuilt the top end. Tore down and cleaned carb. Put everything back exactly like I found it. New fuel filter, new air filter. Drained and cleaned gas tank.
Doesn't want to crank the first time, but then will crank slowly (perhaps needs a starter?). New battery installed.
Once it starts, idles great. Pops and sputters when given gas.
Not sure this is related, but if I give it a lot of gas in neutral sitting still, it will show reverse without me touching the shifter. Also is tricky to get to stay in neutral so it will start. Also doesn't want to go into first gear, but will by playing with the shifter.
Any help is appreciated.
