1 - 3 of 3 Posts
· Registered
I own a Dragonfire edition Yamaha rhino that I have been trying to get working again and I need help if you know anything about this vehicle please call me at 520 610 3042. it will start every now and then but it won't stay running unless I am pushing the gas pedal. I have driven it a few times but as I said I can't let go of the pedal or it will stall.
· Administrator
Start with draining all old gas out and new in.
· Registered
Fuel pump go to eclectic from what I read.
Hope it gets your problem solved and they cheap too.
Good luck but at least isn't a cheap knock off so you be fine.
Sites like this sure helps a guy out tons
Good luck but chances are you fixed it already.
If you did post back what you found as helps everyone out.
Man wish these places were there about 45 years ago. Sure helps and gives idea most weekend mechanics never think off me Lol
But 3ngines were mush simpler back in my day as a kid starting out fixing my toys Lol.
So thanks to all that shared back and great people sharing which sure helps.
What color is your spark plug tan black white???
NGK plug I hope as sure always ran so much better than some others I tried over the years now always NGK
I found ALSO TRY spraying water all over the engine hosed etc see if if it bogs out as could be vacume leak and that the easiest way to check or either and blow your self up.Water works fine when I need to check on mine but I just starting to get harder to start.I starting with a electric pump as no one ever said mistake doing that and most who reply say they like them.
Have fun as if you get mad walk away for a while as I get so mad at the idiot helping me which is me too.
But always get it just some faster then others.
I should also say carbs off amazon are cheaper than a kit to rebuild.
Never tried on a rhino but my ride on mower my weed Wacker even a Yamaha 50 sure worked out well and are like 50.00 in Canada.Go get a price from the dealer insane
1 - 3 of 3 Posts
