1 - 15 of 15 Posts
· Registered
New member, first time post. I'm glad I found this forum. I have an 06 Rhino 660. It has been great up until recently.
It started when it wouldn't idle. Then I would step on the gas and it would stall. Now the only time I can get it to run is by using the choke. If I crank it with the choke, then turn the choke off, it stalls.
I just replaced the fuel filter and it didn't seem to help much.
Should my next move be idle speed adjustment, carb cleaning, or something else. Thanks for the advice.
BTW, it's bone stock. No mods.
· Registered
How old is your fuel and have you replaced the spark plug? check your vacum lines.
· Registered
Discussion Starter · #6 ·
Thanks everyone. I'm pretty good with mechanized stuff so I trust this shouldn't be too difficult. I'm assuming that if I remove the plastic shroud and air cleaner, I should see the carb? I honestly haven't looked at it much. Anyone have a pictorial on how to do it or is it easy enough to figure out once everything is apart?
I'll probably take the time to change the plug. Gas is pretty new as well.
On the subject of gas, is there any concern about ethanol in the gas? I own a yamaha 4 stroke outboard powered boat and there is great concern in the marine circles about ethanol. Opinions? Great forum everyone.
· Registered
no issues on fuel for the rhino like you outboard.
you will se the carb easy enough. and yes it is easy to clean, although the philips screw can be a pain on the bowl.
· Registered
Fram PH6017A and purlator makes a filter but i forget the number.
Purolator pure one PL14610 or PL14612 (shorter stock size one) about 6.50 at PEP boys, better than stock Yami one IMO after seeing the cutaway pics. :good:
BTW great to meet you at the AZ races, wish I had more time to BS and put Ryder in the Flyin banana for a pic
· Registered
Discussion Starter · #12 ·
So, I could use more help.
Got the carb torn apart, cleaned thoroughly, etc. Put everything back together and it still won't idle. Might be a touch better, but not appreciably. It still will not idle without the choke. When the accelerator is depressed, it hesitates significantly.
Spark plug is new. Air filter is new. Carb is clean. Fuel filter is new. What next? Fuel filter, CDI, exhaust leak? This is getting old.
· Registered
i was having a simular problem for the longest time until i finally figured it out. first of all you need to install a low volume electric fuel pump and elminate the stock fuel pump. you can get this at your neighborhood auto parts store, i would have to research it but i could find the part # and brand if i needed to. next you"ll need to replace you're fuel suction hose from the fuel tank and replace it with a 3/8 fuel hose and use soft mechanics wire to use as a twist clamp. the stock fuel line was collapsing on mine. this was the whole problem on mine anyway and now it runs like a champ
· Registered
SOLVED ------
On my 2007 Rhino 660, Just an update, as nothing in this thread solved my issue. The exact symptoms I had were as follows:
Engine starts and runs great. Until it gets hot. As soon as the engine is hot it begins backfiring, then dies, and will only restart with the choke fully engaged, and only then after sitting for a minute. I am guessing this is due to it becoming overloaded with unspent fuel. If you let it sit for about a minute, it will start back up but is unable to run for more than a few seconds at full throttle before the engine dies again. This basically puts the Rhino in limp mode.
Things I tried to do to solve the issue:
1. Rebuilt carborator
2. Changed spark plug
3. New CDI box
4. Ran a half a tank of fuel with Sea Foam additive
5. New spark plug wire / coil
6. New air filter with foam air filter oil
None of this had any effect on the symptoms at all......
The Fix -------------------
On a hunch i got out my volt meter and tested both output voltage and continuity on the leads coming out of the engine from the stator both right after firing up while it was still cool, and again when it was hot. It was faulty when hot.I am guessing this was due to thermal expansion of one or more of the coils, or a thin insulator wire caused from wear and age.
So, after ordering a new stator, and spending about 5 hours taking her apart, installing new stator, and putting everything back together, I am happy to report that i just went trail riding for over an hour and not a single backfire. I was running her pretty hard at full throttle a lot fo the time.
Replacing the stator requires draining the oil and coolant, so those were replaced with Yamaha recommended fluids, plus a new K & N oil filter. I also replaced the stator housing gasket, and the water pump gasket while i had everything open. I used locktight on all threads on reassembly of all components and a super thin coat of RTV on both sides of both gaskets.
It now runs like its brand new.
· Registered
great news and thanks so much for sharing. Most got their running never hear back so well done.
silcon on both sides I do not understand why really.
Seeing Im very old school I use grease never have i had a leak but the choice is yours but I like grease as if I need to take apart I still have gaskets and the price now completely insane.
I have a whole 1400 hours on mine but use mostly for snow removal now only.
I getting old I guess time to sell my honda 450 F as thats machine is crazy fast.The front end will come up at any speed and first 4 stored bike I ever owned but great bike I bet I do not have 50 hours on her.
The power scares me really but was in a bad bike accident in 1986 broke most every bone said I wouldnt live the night then was I never walk.
Well tons of pain 24 7 but still love motor sports but trucks seem choice now the comfort man I am getting old Lol enjoy riding everyone but be safe ruined my life so dumb driver pulled out in front of me with less then 2 seconds to react. Happens so fast.Not worth a live time of pain and working well stopped at age 55 when I was reduce 85% WITH THE SAFE THE college does.so share the story to let people know the other side which sucks.I live longer with pain then without.If I help one person out with my dumb story would sure make my life worth something.
But I used to love riding playing with kids but that all changed.
Happy riding to all
1 - 15 of 15 Posts
