the fan on the radiator stopped, it is freed up and will run when hooked to a power source. but it doesnt run when it is suppose to. this tells me the fan is ok but a relay/fuse is bad. anyone have this problem, idea to fix are appreciated.
check the fuses in the battery box, also there is 2 wires that go to a gel pack in there, that is the temp relay thingy, not sure if they go bad, but you can clip the wires and wire them together and see if the fan works to eliminate it as the problem.
