Yes I am behind the time on this swap ordeal I have the 660 now I'm gathering the odds and ends for the 800 swap i have the 700 tank with in tank pump i believe the 700 is 42ish psi and the 800 needs 56 or somthing around that neighborhood what options have you swap guys used for pumps with out using the aluminum tank and can am bottom fed pump assembly thank in advance
Mine was an 06 660 and I used the stock fuel tank. I added an ~1 gallon SS tank underneath the driver's seat that I put my 06 Outty fuel pump into it, then replumbed accordingly from stock tank with a low psi transfer pump . Seems the Rotax fuel pump specs were listed as 48-50 psi.
Several guys used fuel cells in the bed and went that direction also.
Related Threads
118.2K posts
8.5K members
Since 2008
