1 - 12 of 12 Posts
I tried a highflow one and it worked o.k
couldn't really tell the difference between the stocker though.
I have 2 electric pumps in my rotax and knock on wood, I haven't had any issues(YET)
I am running a electric pump......My fab guy though he had a great idea to relocate my stocker and it would no longer work.......so instead of fuckin with puttin it back I bolted on a faucet pump. Works like a charm and starts RIGHT up
im running the BRP one it works but the only problem i see is if the switch fails or pump takes a dump your stuck in the desert. the stock one works good enough also if you roll the electric pump will stay running and could shoot gas all over the motor and start a bad fire. this does cross my mind running the electric
I would say run a diaphragm one like stock
I would use a stock pump unless you have or plan on modifying you rhino. In the long run it will make it easier to troubleshoot the fuel problems because all the spec are in the manual.
K.I.S.S. (keep it simple stupid)
1 - 12 of 12 Posts
