Reverse Light
8.4K views 5 replies 4 participants last post by  spooledup24v
#1 ·
Today I started my rhino and let it Idle for a few minutes and the reverse light started blinking and then it died. Does anyone know what this means or have seen it before?
#3 ·
Mine started blinking last week while driving. However I had no ill effects. I stopped and checked everything, oil and wire connections. All was fine so I kept going with no issues. I called my local Yamaha shop and they said it is nothing that Yamaha has pre-programmed so it must just be a short with the reverse switch.
#4 ·
I believe it was either the battery needed to be charged or the ground wire. When I went to charge the battery I noticed the ground wire was pretty loose. Since I did these two things it has not come back on. Thanks for the reply.
