2004 Rhino 660 - My rear parking brake is leaking oil at the worm gear arm. I have dissasembled it and installed a new gasket and rubber O ring but it still leaks. My worm screw does not have a punch mark on it that designates how far it should screw in before adding the lever on top of it when assembling. There are no marks on the lever or housing as well. Can anyone tell me how far to turn in the worm gear before adding the lever on top? Also, I added the O ring but there doesnt seem to be an indention for it to sit in. Is that normal?
